Re: distributor cam Super H worn
Posted by Janicholson on October 29, 2014 at 20:14:14 from (74.60.94.18):
In Reply to: Re: distributor cam Super H worn posted by chuckj1954 on October 29, 2014 at 11:41:09:
Any variation in the base square, or the tip of the rounded cam corner will cause a radical change in timing. It is not the amount of opening that really matters, it is the precision of the moment of opening. It would need total reshaping in a mill with an index head to assure it was symetrical. (not practical for a reasonably easy to replace component. Were it a one of a kind expensive component sure. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
