Posted by K-Mo on October 30, 2014 at 03:39:03 from (66.43.226.235):
In Reply to: Cub manufacture date posted by Mikein Ky on October 29, 2014 at 18:26:13:
On early tractors the chassis and engine serial numbers matched. If the engine casting numbers and the chassis casting numbers are all 1951 and the engine serial number is 1951 and assume the engine has not been changed, you could declare the tractor to have the same serial number as the engine. No guarantee, but probably the best guess. As production entered into the mid 50's, matching chassis and engine number went away,
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
