Posted by Janicholson on October 30, 2014 at 08:58:39 from (199.17.6.160):
In Reply to: Super H distributor posted by chuckj1954 on October 30, 2014 at 08:35:20:
Were it mine, I would put the shaft (apart) in a good lathe and use a dial indicator th assess the lobe geometry. (bent or worn or made wrong to begin with) If the squareness is OK, but off center, it will never give reasonable results. If the cam is actually off center, the magnet that fits on the cam will also be off center and thus have variable distance to the pickup module. Finding a different cam shaft should be pretty easy even a worn shaft that is evenly dimensioned from centerline, (try Bates Equipment in Indiana) will be OK for replacement with an electronic system (this site has them for 6v Pos or Neg ground) It will run so much better when timed correctly on each cylinder that it will be a miracle. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
