Re: Red Green Hydraulics
Posted by IH fan on October 30, 2014 at 21:18:29 from (68.102.228.127):
In Reply to: Red Green Hydraulics posted by Kelly in tx on October 30, 2014 at 07:33:50:
Simple answer on open or closed center is in an open center, the pump pumps continuously and the valve(s) have a spool design that allows fluid to pass through unrestricted when in neutral or center position and back to the reservoir. A closed center, the fluid is blocked when the spool(s) are in neutral or center position. In this case, either the pump has to return to a "standby" or near neutral position, or there has to be a separate valve that by-passes the flow and maintains a near zero standby pressure. Many systems today have a pressure/flow compensated pump that returns to a near neutral cam position in a closed center position. These systems react better than an open center because pressure and flow are instantly available when the control valve spool is moved.
Simple explanation of course, and in many modern systems it gets more complicated, but that's the basics.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
