the ring gear is on the flywheel. check the teeth on the flywheel to see if they are still good. you would have to split the tractor to replace the ring gear. or, the gear can be removed and flipped over to use the other side of the gear. i didnt see the pic either on this site store, but you can call them for more info. i have ordered quite a few parts from this site and have always been happy.something to check also, is how far the bendix is traveling to engage the flywheel. there are some shim washers on the armature that set the distance. lay a straight edge across the starter mounting hole on the tractor and measure in to the flywheel teeth . then compare that to how far the bendix on the starter travels. you may need to swap the shim washers on the armature.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
