Re: H timing/distributor question
Posted by Bob on October 31, 2014 at 12:30:33 from (64.255.159.192):
In Reply to: H timing/distributor question posted by bassmasta76 on October 31, 2014 at 11:50:42:
"Clock position" of #1 and the other wires does NOT matter so long as #1 gets fired at the correct time and others follow in firing order sequence.
The factory had a "standard" way of setting up the ignition wiring so every new tractor was the same, and it's good practice to keep the wires in that arrangement when repairs are made (distributor removed and replaced), but it doesn't make the engine run and better than yours will now, if ignition timing og #1 is to "spec".
Instead of observing the firing order from where #1 is "supposed to be", simply start at #1, then (CW) 3 - 4 - 2.
  Upload Photo  Select Gallery Photo  Attach Serial No List
