Posted by Joshua Rod on October 31, 2014 at 16:11:21 from (172.56.11.113):
Super C. I just finished a complete overhaul, sleeves and all, about two weeks ago. Its been running good for the first three hours or so of run time. Today a high pitched squeal developed and sounds like it is coming from the very front, up around the accessory belt. After a couple of minutes of run time, just to get back to the shed, it starts smoking a bit up front. I have lube in the fan assembly. Is there anything that you guys have dealt with that sounds obvious? Alternator or water pump pulley bearings? I havent had time to look because i had to get the little goblins ready for tonight.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
