If the previous suggestions don't solve the problem, take the platform off on the top of the transmission. That will let you see what moves and what doesn't. If the reverse still is stuck try a wrench on the reverse lever on the top of the lid. It will be the one to the farthest left looking down at it setting in the seat. The engine MUST be OFF for this if not either you will be run over or the teeth broken off inside. It should move with a gentle pry of a screw driver. The wrench is just easier to get hold of the lever with. It will move about an 1-2 inches on the end of the lever. only 2 positions in or out. The other rod you will see is the HI LOW shift linkage. They could have rusted under those levers where they go through the cover to the forks i suppose if it was left out side.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
