glow plugs
Posted by Glenn D on November 01, 2014 at 12:36:30 from (24.114.72.95):
Hi folks
I changed out the Glow system in m B275. one of the original plugs (closest to the front) had to be coaxed out a tiny bit at a time working it back and forth. the threads looked ok on the one I removed, I don't have a tap or a thread chaser for that size hole and the new glow plug won't quite thread all the way to the bottom. Needs another 3/4 or full turn to go all the way.the question is can I run it this way until I can get a tap into the hole? or am I stuck until the mll supply is open again?
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
