You didnt put oil in the fan assy and now if it wiggles it is shot and you need to replace the whole fan assy. The new ones have bearings and need no lube. But you will need to buy a new one which will be a complete assy. You will need to remove the radiator to replace it. The nut at the back of the bracket does NOT turn you do use a wrench on the place in the FRONT of the bracket and loosen it. The nut on the rear is oversized and slides in the bracket up and down to tighten the belt. You understand how the assy slides up to tighten the belt when you get the old fan assy removed but thats the way they are made. So start looking for a replacement NEW fan assy as all the used ones on ebay are probably bad or have play and are next to being junk.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
