Re: High pitched squeal revisited
Posted by Joshua Rod on November 02, 2014 at 08:32:48 from (172.56.11.113):
In Reply to: Re: High pitched squeal revisited posted by teddy52food on November 02, 2014 at 08:09:27:
When i hold the fan it can by the outer edg of a blade i can move it forward and backward quite a bit. But this just started all of a suden, which makes me think the bolt holding the assembly worked loose. But the only way i can see to tighten it would be to take the radiator off.
  Upload Photo  Select Gallery Photo  Attach Serial No List
