Re: injectors
Posted by Dieseltech on November 02, 2014 at 14:53:50 from (199.16.223.2):
In Reply to: injectors posted by carlsandberg on November 02, 2014 at 14:11:24:
Injectors will not cause it to slowly stop if it runs good 4-5 minutes. Take the fuel line loose at the filter inlet and check fuel flow. Does it flow OK a few seconds then slow down? Could be a tank or restriction, or tank vent plugged. No air in means no fuel out. Not sure what filters are used, but if they are NAPA 3166 make sure there is no extra O ring in the top filter fuel inlet groove, that will cause trouble too.
  Upload Photo  Select Gallery Photo  Attach Serial No List
