Re: 300 water pump
Posted by Nebraska Kirk on November 02, 2014 at 15:00:38 from (207.91.4.159):
In Reply to: 300 water pump posted by Bradiniowa on October 30, 2014 at 18:26:17:
I for one think it is a pretty good design. It is easily and cheap to rebuild. The same basic design began back in the early 1930s on the F30, W30 and T20. The same design was used into the 1940s and 50s on the letter and number series tractors and as a matter of fact, many parts will interchange between them. For example, while rebuilding the water pump on my 1936 WA40, I found the impeller to be severely rusted away. After looking through my parts books I discovered that while the main housing is different on most tractors, the hub, bearings and impeller are the same between many of them. I had a 450 water pump on the shelf that came off a salvaged tractor so I took the impeller out of it to use on the WA40 pump, perfect fit!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
