The gasoline, LP, and diesel starters all use the same size ID starter drive. The gasoline engines first came with a 9 tooth starter drive with a gear OD of 29 mm. Later ones along with Hydros and LP engines used a 10 tooth drive with a gear OD of 32 mm. Diesels used a 12 tooth drive with a gear OD of 36.3 mm.
Use drive number 1970544 with the diesel starter. It has the same size drive gear as the larger of the two options for the gas starter but uses a spragg clutch rather than a roller clutch.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
