Posted by nebraska cowman on November 03, 2014 at 04:05:26 from (66.252.116.102):
In Reply to: Overheating H posted by Redturbo on November 02, 2014 at 20:22:27:
You did not say if the radiator was plugged so solid that no coolant is circulating. And in the pic of the block where the side plate is off it looks like part of a side plate deflector is still in there. The side plate should have two deflectors spot welded to it that stick out an inch or so from the plate. They rust off. Pry that out and get a new side plate (I have them in stock) The H is pretty easy to cool if anything is any where near where it should be. I don't think you need to remove the block.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
