Re: 1066 lever by brake pedals
Posted by mkirsch on November 03, 2014 at 05:46:39 from (72.45.143.81):
In Reply to: 1066 lever by brake pedals posted by 67chevrolet on October 26, 2014 at 10:54:14:
If it's going to sit, it won't hurt anything to get yourself a can of your favorite penetrating lube, like PB Blaster, Kroil, WD-40 PENETRATING LUBE (not regular WD-40) or a spray bottle of ATF and acetone mixed 50/50.
Leave it sit on the platform of the tractor, and give each pivot point a shot of it every time you walk by. This is the perfect situation to use penetrating lubes.
