Or, it could simply be that your main battery cable connections are corroded.
Just recently ran across the same problem. We fiddled around with it all day. Everything looked perfectly fine. There wasn't a flake of that white stuff anywhere. All the connections were tight.
Starter turned over fine when we bypassed it with a jumper cable on the positive side. Wiggled the positive battery connection. Nothing. Took it apart. Looked perfectly fine. Put it back together. Nothing. Took it back apart, ran the battery terminal cleaner tool down on the post, and up through the clamp. Put it back together, and it started right up.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
