Posted by gene bender on November 03, 2014 at 06:33:21 from (67.55.226.121):
In Reply to: max. rpm posted by Fire50 on November 03, 2014 at 05:55:23:
Wit the engine off remove the clevis pin going to the carb. Now open hand throttle then adjust the clevis holding the throttle rod going to the carb wide open. The clevis probalbly will be hard to turn and you should remove that rod from the carb so you can get the clevis to turn free and easy. If then you want more RPMs turn the cap screw on top of the gov housing out. That should solve your problem unless the gov spring in the gov is broke.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
