Posted by Oregon Tractor Jack on November 03, 2014 at 07:09:36 from (50.137.138.152):
In Reply to: Overheating H posted by Redturbo on November 02, 2014 at 20:22:27:
The side plate should have a sheet metal water guide spot welded to the plate. This helps direct water to the back of the block as an aid to cooling. I had one H that always ran hot. I found the water guide had rusted away. You might want to replace when you finish cleaning the block out. I never had one quite as plugged up as what you have. That is going to be a chore to get out.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
