What I found was the fingers on the pressure plate were out of adjustment. The tips of the fingers were too close to the pressure plate.
When I pushed the clutch pedal in part way the clutch would release.
When I pushed the clutch pedal all the way in it would grind.
The yoke that holds the throwout bearing was pushed too far forward and hitting the adjustment screws on the pressure plate fingers.
I had to adjust the pressure plate fingers out away from the pressure plate.
If that's what you have going on you'll need a 1/4" drive ratchet with a flat screwdriver bit in a 1/4" socket. And an end wrench for the locknuts.
I took a piece of wire and bent an L on one end that was 1-1/4" long. That way I could stick the wire up in there and use it for a gauge to measure clutch finger height.
It wasn't much fun laying on my back and working thru that little hole in the bellhousing.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
