Re: gear reduction starter for farmall 656 gas
Posted by Owen Aaland on November 03, 2014 at 20:22:01 from (216.47.34.49):
In Reply to: gear reduction starter for farmall 656 gas posted by gr gold on November 02, 2014 at 18:53:11:
The gas starter should have either 1939109 or 1851427 as a drive assembly The first is a 9 tooth drive and the second is a 10 tooth drive. 1851427 is basically the same drive as 1970544 with the difference being the first one has a roller clutch and the later one a spragg clutch. Either will work but the spragg clutch will take more torque than the roller clutch before failure. As long as you are not completely sure the diesel starter will work for you, you could just use the drive you have. If the starter will do the job for you just replace with the heavier drive if and when you have a failure.
