Posted by Owen Aaland on November 03, 2014 at 20:29:21 from (216.47.34.49):
In Reply to: IH 1066 shiffter posted by farmallzach on November 03, 2014 at 10:17:04:
Remove the panel between the clutch and brake pedals. Look at the shaft and coupler just above the speed transmission cover. Most likely one of the pins has come out. There should be tapered groove pins to connect the shaft to the couple. If you replace the original pin with a roll pin be sure to use two, one inside the other. Use a piece of wire to make sure the pins do not come out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
