Re: Hooking up 3point to Farmall Super M?
Posted by mkirsch on November 04, 2014 at 06:57:01 from (72.45.143.81):
In Reply to: Hooking up 3point to Farmall Super M? posted by asburytl on November 02, 2014 at 18:01:34:
Use the third remote valve on the loader.
Install the 3pt on the tractor.
Tie the top ports on the two cylinders together with short hoses and a TEE fitting.
Tie the bottom ports on the two cylinders together with short hoses and a TEE fitting.
Run a hose from one TEE to one of the capped ports on the unused remote.
Run a hose from the other TEE to the other capped port on the unused remote.
You will need a few swivel fittings in strategic locations to make the final connections. You will probably also need some elbows so the hoses aren't sticking out all over.
Get an old garden hose and use it to figure out how you're going to route the hoses and how long the hoses need to be. Hoses should be tucked away from any moving parts, not hanging down below the tractor, and not in your way. Zip ties come in handy.
