Farmall Tractors Discussion Board
Re: Farmall H 6v to 12v conversion?
Posted by donald on January 23, 1999 at 08:28:20:
In Reply to: Farmall H 6v to 12v conversion? posted by Robt on January 09, 1999 at 09:24:15:
Yes its easily done.Have generator rebuilt adding
to more fields to it.Cost about 60.00.Install 12v
coil.The old delco remy 12v works fine.You will need to change from pos. to neg.ground.The process
is to reverse the polarity at the voltage regulator.I have the steps but can't locate them now.If you have the system upgraded the repairman should know what this is.I keep looking for the
steps I have and let you know
Post a Followup
: Re: Re: Farmall H 6v to 12v conversion?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
