Posted by glennster on November 04, 2014 at 15:00:08 from (162.204.229.223):
In Reply to: Overheating H posted by Redturbo on November 02, 2014 at 20:22:27:
get a candy thermometer or an automotive coolant test thermometer and drop it in the radiator and get a temp reading. im thinking you are not getting a good coolant flow from the block. if i remember the h sender is in the head. could be your passages are plugged up . if the tractor is where it will not freeze due to temperature, fill the coolant system with straight white vinegar and let it set a week. vinegar is a very mild acid and will dissolve rust and calcuim and not hurt the block. then give it a good flush.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
