Re: gear reduction starter for farmall 656 gas
Posted by used red mn on November 04, 2014 at 19:08:20 from (76.113.131.26):
In Reply to: gear reduction starter for farmall 656 gas posted by gr gold on November 02, 2014 at 18:53:11:
A little off topic, but I wouldn't recommend using that tractor like it is 100hp drawbar machine to do tillage. The rear end in it is not that stout. The one we had we had trouble keeping the rear end together behind the original gasser. It was however our main tillage tractor at the time.
  Upload Photo  Select Gallery Photo  Attach Serial No List
