Posted by NNP on November 06, 2014 at 04:41:56 from (66.66.112.196):
In Reply to: Overheating H posted by Redturbo on November 02, 2014 at 20:22:27:
lots of good suggestions.
working with an unknown radiator, couple of quick tests I do.
bottom hose off, garden hose on full flow stuck in the radiator neck. Draining thru the radiator should stay ahead of the hose flow easily.
plug the inlet/outlet of the radiator. Fill and then drain it into a bucket and see how much it holds.
I take the thermostat out temporarily when flushing/cleaning a nasty one. I want to actually see the return flow to the radiator when it's running. Should be very violent.
(and especially nasty ones, I might leave the thermostat out for a few days when all that junk coming loose is still circulating. They will get plugged)
Once done, on to the engine.
lean is hot,
but the most common hot problem I see is a stuck or malfunctioning advance mechanism.
If it is stuck/sticking, no advance when rpms come up and a very, very hot engine, exhaust side, will result.
(they sound 'louder' and the exhaust components will be white and crackling hot when this is the case)
A small combustion leak into the water jacket will get that temp climbing too.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
