Re: Do you need to remove frontend to remove radiator on M?
Posted by michaelr on November 06, 2014 at 09:20:44 from (216.66.79.38):
In Reply to: Re: Do you need to remove frontend to remove radiator on M? posted by unioncreek on November 06, 2014 at 08:50:34:
Yes, when you place the radiator back on, place as many donut spacers as you need around the bottom radiator bolts, so that the radiator sits on them at the height you want it, takes some trial and error. There is enough room for adjustment that the fan does not hit the shroud. I had a wide front on my M, previous owner had already torched the holes out so I could put a long extension on my socket to get the bolts out. Hardest part was getting them back in because of the preloaded compression springs.
  Upload Photo  Select Gallery Photo  Attach Serial No List
