Re: Farmall M LPG Hood cutting
Posted by redgems on November 06, 2014 at 10:39:29 from (204.14.163.20):
In Reply to: Farmall M LPG Hood cutting posted by JohnG(TX) on November 06, 2014 at 08:33:08:
JohnGTX,
my I.H. TC-46 parts manual lists#1 56513dbx hood for gas SM-SMV .501up to 52627
#2 357-093-R11 hood L.P. SM-SMV 501 to 52627
#3 360-523 -R11 hood Gas SM-SMV 60001-UP
SMTA's are 60001 on up so I would think a 357-093 R11 from a SM l.P. would be the one because the extra length of tractor begins behind bell housing front tank mount is in same location as SM and rear tank mount is on the hydraulic tank.
My hood has a slight semi circle to fit snugly to tank.
The little decal I mentioned in above above is on TC-46 page 217 on right side of tank says This tractor equiped at factory.
Tony
This post was edited by redgems at 10:43:49 11/06/14.
