I cut out flat circles and bolted them to the hub with the lug nuts. only four lug nuts hold the plate on. the others are drilled over sized so the lug nuts mate against the rim. then the plates are drilled for all thread. this way I can run 1/2 weights, up to 5 sets.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
