Posted by John T on November 07, 2014 at 06:33:53 from (216.249.72.121):
In Reply to: 12 conversion coil posted by bhshot on November 07, 2014 at 06:12:26:
SURE, if you added a series voltage dropping (12 down to 6 volts) Ballast Resistor you can use a 6 volt coil on a 12 volt tractor.
If you don't add the ballast and applied 12 volts to a 6 volt coil, it will overheat bad, eventually fail, and the points will burn up prematurely. But Billy Bob might say it will still "work" at least until it burns up lol
Your exact question: "Could I have left the 6v coil"
YES you could have left it
"and would it have worked?"
YES for a while until it burns up
I THINK YOUR CHOICE TO BUY THAT 12 VOLT COIL WAS WISE or you could have bought a voltage dropping (12 down to 6 volts) Ballast Resistor instead that would have been much cheaper and that would have still worked properly...
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
