Re: SMD rear main seal conversion
Posted by D Slater on November 07, 2014 at 07:04:56 from (184.14.184.128):
In Reply to: SMD rear main seal conversion posted by DanMD on November 07, 2014 at 06:42:23:
Only the die cast or aluminum ones for the felt seal that I know of. Top half of the die cast is the same as the gasoline engines. You can see the number on all the iron ones I see. If the numbers are 271792R1 and 271793R1 that's for the rubber seal.
