DGK, The marvel carb on my 1950 IH C is the same way. I even put 2 washers between spring and jet to keep jet in place. My carb has only one adjustable jet. It works backwards from what you would think. Turn it all the way in and fuel mix goes rich. Turn it all the way out and the fuel mix goes lean. Mine works great all the way out and I'm not taking it apart. My plugs were black and tractor drank gas when jet was all the way in. Now, the plugs look line new ones, all white.
So run yours for a while, then look at plugs.
I purchased a cheap sand blaster, spark plug cleaner from HF so I cleaned them and they work great. george
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
