Re: IH 856 and chisel size
Posted by The tractor vet on November 08, 2014 at 08:53:31 from (104.179.81.68):
In Reply to: IH 856 and chisel size posted by mjordal on November 07, 2014 at 18:33:58:
And 856 with a M&W hair dryer is probably turning 115-120 horse and a seven shank with 4 inch twisted shovels will work well as long as you have a full rack of ft. weights loaded tires and duals . one other thing is tire size , if it has 18.4 x 38's or is it down on 18.4 x34's . You should be able to run first high in descent ground around 8-10 inches deep. My 806 will run a 9 shank straight shovel eight to ten inches deep but it is a three point . We are now DEEP ripping with a barn yard engineered Land Doll disc chisel that now had five DMI parabolic Tiger shanks with seven a half inch Tiger points and five or six inch upper shank shovels and going down thirteen inches or in other words five to six inches into the clay behind a 1066 that is tweaked and weighs in at around 18500 . now normally we can run first high , but Wednesday was not the case as i was ripping one ten acre field that we had chopped corn on when it was to wet in the rain and the wagon tracks in places would take you from 6-7 MPH to 0 in the blink of and eye . I had the pony power but was lacking traction and weight even with the duals .
  Upload Photo  Select Gallery Photo  Attach Serial No List
