Re: fixing burnt tractors
Posted by tractorguy2 on November 08, 2014 at 14:56:31 from (64.147.35.20):
In Reply to: Re: fixing burnt tractors posted by wvfarmboy on November 08, 2014 at 14:35:40:
If the tractor was in a building fire. I think it's done. If it was outside in a grass fire and just got the wiring/tires burnted off. It can be saved.
Back when dad repaired tractors. He repaired a few that were in fires. None were in a building fire. They were mostly JD's that caught on fire while refueling. The mag on the lettered series sat right under the fuel tank. Over filling the tank fuel with engine running would splash fuel on the magneto and away they go.
he also had a few of the hundred series Fords. The under hood muffler would burn out and heat the fuel tank/fuel line if the heat shield was not in place.
  Upload Photo  Select Gallery Photo  Attach Serial No List
