Posted by Owen Aaland on November 08, 2014 at 21:31:19 from (209.105.17.64):
In Reply to: Block Heater for 2424? posted by Tim in New York on November 06, 2014 at 09:47:54:
The plugs, commonly called frost plugs, are just stamped steel. To get it out use a punch on one side and tap it in. as it starts to come loose it will start to twist in the block. Once you get it to start to turn carefully turn it until it is nearing 90°. Then use a pry bar to pull it out of the block. If the punch goes through the plug rather than getting it to move plan on changing them both.
The brand of heater that is common here is Kat's. They should be available at almost any auto part's store though you may have to order the correct one for your engine. I looked on line at the Kat's catalog and your tractor is not listed but a 504 is. That tractor uses a similar engine to the 2424. It list a 1 5/8" heater number 10603 or 11603.
If you go to the Kat's web site you will find a button for their catalog. There is information there about the different heaters and how to install them.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
