The guys have it covered pretty well. The only thing I will add is a IH 86 series is not a good baler tractor. The shifter is a PIA to use. If you move much at all in neutral you will have a hard time getting it into any gear.
As for the TA it is shot. If you can't do the work your looking at $3500-5000 to have it repaired. That is depending how much is broke/worn when you get in there.
The leaking cylinder in the cab is a clutch assist cylinder. It makes the clutch push easier if the tractor is running. The clutch on a IH 1486 or 1586 can be a real hard push for a smaller or older person. Some have real hard time holding the clutch down for the neutral start switch to work.
All in all is sounds like this tractor has a lot of issues. Unless your wanting to do the work yourself and the tractor is cheap then I would pass it by. You can buy a good running one cheaper than one you have to pay to have repaired.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
