Posted by Raymond560 on November 09, 2014 at 18:41:18 from (98.16.139.244):
Recently had a guy "rebuild" the carb for my 560. Tractor has not run right since. It will start pretty easily with throttle wide open. It runs for a couple of minutes and then starts to surge. It will do that, whether moving or standing still, for up to 10 minutes then die. Won't start again for at least an hour. If you reduce the throttle it will die. Any ideas? Help would be greatly appreciated.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
