you have to have the pto out to remove u bolt #2 in picture which is clamped around torsion tube. it will then pull out if the wheel is not too close if the wheels are set narrow the right may have to be removed or slid out on axle to make enough room. make sure you replace the orings (items #3 times 2 and #9)that seal in the oil while you got it apart. in case you didnt know the right bell crand is all one piece with the torsion tube. to reassemble you will also need the top link bracket or cover above pto off to help align the pto drive shaft and it is also a big opening that works well to pout oil in through. be careful the pto assembly is heavy.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
