Re: 450 TA Question
Posted by D Slater on November 10, 2014 at 05:03:04 from (184.14.184.128):
In Reply to: 450 TA Question posted by Ron in Nebr on November 09, 2014 at 21:17:16:
If when the handle is pulled back the tractor stops and a whining noise is heard. My opinion is if you want the t/a to be good take it out and repair. Waist of oil to change before draining to work on it, unless you are going to use the tractor without repairing the t/a.
Without double checking I think 450 tractors came with light engine oil in the transmissions. Think they said the heavy oil could be used if temps didn't fall below a certain temperature.
Memory could be off, someone will correct me if so.
  Upload Photo  Select Gallery Photo  Attach Serial No List
