Re: 450 TA Question
Posted by mkirsch on November 10, 2014 at 11:40:40 from (72.45.143.81):
In Reply to: 450 TA Question posted by Ron in Nebr on November 09, 2014 at 21:17:16:
Can't say as I've ever read about anyone replacing hytran with hytran and their TA starting to work.
It's the heavy viscosity of the gear lube that "gums up" the TA and keeps the ramps and rollers from engaging. Water doesn't increase the viscosity of hytran anywhere near what it would take to match gear lube. I don't think water increases the viscosity of hytran at all, in fact.
Not sure what your opinion on using "compatible" oils are but you could save a lot by going with generic hytran compatible for the rear end since it's not going through any pumps or mixing with any hydraulic systems.
