Re: 450 TA Question
Posted by D Slater on November 10, 2014 at 16:00:11 from (184.14.184.128):
In Reply to: Re: 450 TA Question posted by Harry Klever on November 10, 2014 at 09:05:02:
Looked at a f-450 operators manual I have printed 3-7-58. It says use SAE-75 gear oil or a mixture of one quart IH torque amplifier transmission lubricate additive to each 4 gallons of SAE-10 or SAE-10W engine oil with a T/A.
F-350 one printed 6-57 says use the 10 weight and the T/A additive to ever 4 gallons.
F-400 manual 1004381R1 printed 10-28-54 said use SAE-80. Later F-400 manual 1004381R2 says use the 10 weight and additive.
Everything changed since then and one reason for the changes along the way was IH having complaints about the T/A operation in cold weather.
  Upload Photo  Select Gallery Photo  Attach Serial No List
