Posted by rustred on November 10, 2014 at 18:02:09 from (74.214.152.80):
In Reply to: International 660 diesel posted by bill from scotland on November 10, 2014 at 06:45:18:
its a dry sleeve engine. so you may have a crack in block between the sleeve or even both. also head gasket as these engines are very prone to head gasket leaking. least probable is a cracked head, as this will send compression into the rad. usually when the oil cooler gives out you have oil in rad, not anti freeze in oil. best is to remove pan and dry things up with brake kleen and place cardboard under engine overnight. usually can see where leak is coming from.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
