Re: Buddy seat in a 86 series cab.
Posted by Owen Aaland on November 10, 2014 at 22:10:55 from (209.105.17.64):
In Reply to: Buddy seat in a 86 series cab. posted by dmiller on November 08, 2014 at 21:54:38:
The brake master cylinders are on the engine side of the cab above the brake pedals. The clutch booster is in the same location on the left side of the cab. A cylinder leaking under the brake pedals is probably an auxiliary valve.
The transmission brake is internal in the bottom of the speed transmission.
There was a change in the park lock pawl and spring on the later tractors to make it a bit easier to get out of park. Later tractors also had an additional safety start switch on the park lock linkage allowing the engine to be started when in park without having to depress the clutch pedal.
The TA doing nothing when shifted could well be a problem with the cable. Either a locating clamp comes loose or the end of the cable or linkage is broken. An improperly adjusted clutch, transmission brake, or TA dump valve can all make the transmission hard to shift.
This post was edited by Owen Aaland at 22:12:29 11/10/14.
