Re: 240 throwout bearing
Posted by pete hall on November 11, 2014 at 06:43:01 from (70.210.225.148):
In Reply to: Re: 240 throwout bearing posted by Bob on November 11, 2014 at 06:23:50:
Bob you are correct,my description is not good
I have a new sleeve(part 20) but my guide(part#21) is bent up at the clutch end.
can I cut off the bad end as it is about 2 inches longer than the sleeve(part#20) and still use it?
If not are these still available?
I have read references to carbon inserts,Are these necisary as mine had none?
thanks again for the help
pete
  Upload Photo  Select Gallery Photo  Attach Serial No List
