I run ethanol gas all the time in everything. No problems except for winter storage. On the tractors that I use in the winter I use stabil in the gas. For the ones that will be stored, I drain the tank, buy a few gallons of marine gas(which has no ethanol)& mix in some stabil, then run them a bit. I know it's overkill but it's easier than cleaning carburetors and gas tanks.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
