Re: 240 throwout bearing
Posted by gene bender on November 11, 2014 at 18:10:56 from (67.55.226.121):
In Reply to: 240 throwout bearing posted by pete hall on November 11, 2014 at 05:16:25:
The sleeve is pressed into the bell housing and the bearing slides back and forth and the ends must be not bent or deformed
  Upload Photo  Select Gallery Photo  Attach Serial No List
