Re: 42 H with gravity trip bucket Stanhoist loader
Posted by Janicholson on November 11, 2014 at 21:25:57 from (74.60.94.18):
In Reply to: 42 H with gravity trip bucket Stanhoist loader posted by carpenter on November 11, 2014 at 19:29:47:
There are no simple hydraulic solutions because the H pump, or any single pump, will displace fluid into the easiest to move cylinder first. A complex hydraulic solution is 2 accessory pumps one for each cylinder. Or a single cylinder pushing two slave cylinders each hooked to one of the lift cylinders. Complex.
A common way to stiffen the loader is to put a tube of fair size 6 inches dia and 3/8 wall thickness) at the pivot point on the frame (if possible), or just behind the bucket. It must be welded to the rails so the rails are forced to act as one. Show us a picture. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
