Re: Ethenal gas and cold temps.
Posted by DaninKansas on November 12, 2014 at 05:37:38 from (24.248.193.103):
In Reply to: Re: Ethenal gas and cold temps. posted by rhtx55 on November 11, 2014 at 19:19:44:
Run the highest octane fuel you can afford, Sunoco 260, or av-gas is the best, but 93 is next, and 85 will work ok for light duty.
Because there is nothing like throwing away money for absoulutely no reason. Aviation fuel in 1940s Farmalls?
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
