53 sa engine
Posted by rray on November 12, 2014 at 06:44:25 from (108.198.198.73):
I had a small water leak between the head and block so I pulled the head to replace the gasket. Initially the engine looks good. This tractor will probably never do real work again. It was my grand dad's and I am restoring for the hell of it. The engine runs pretty good with just an infrequent miss with no load. Should I go for a head rebuild while I have it off? What else should I look at while I have it down? The new head gasket says sealer required. What is recommended?
Richard
